TJ won't start
Thatbluejeep
Weston idaho
so I put my new motor last night and it didn’t start so I thought it was a fuel issue and I switched my relay from my horn to my fuel pump because the fuel pump relay was blown, and it started right up, ran for five minutes and then it died again and now I have no spark and no power to the coil, and my horn does not have power to the relay
Hey I have power to my injectors and my coil, but I can’t seem to get any spark and I just replaced the cap on my distributor and the inside part that spins around can you help me please
I also checked and I have power to my injectors and my coil, but I still am getting no spark and I have replaced most of the distributor besides the bottom half
When you checked power to the coil; did you only check the power at the positive terminal of the coil or did you check power across the positive and negative terminals while cranking the engine over ?
IF you only have power to the coil positive terminal and not the negative; you need to determine why not.
