Are there any markings as to what the axles are rated for?
I can check for that later too
I'll mostly likely end up basing it on this
I can take a pic underneath it today... I can always reinforce it and get new leafs if I must, right?
What size tires? What are their rating?
That frame looks pretty heavy duty
Not sure on the tires, they're fairly new, I believe my friend had to buy them to get the trailer around his yard or something. I'll check them out when I take the dog out.
Thanks for helping me check all the important bits
Goddamnit. Fucking metalcloak. The hardware they ship with their shit is allen-key bolts but its like they powder coat it so the only way to get an allen into it is to hammer it in. And now I've got this bullshit to deal with because of it. Now I get to take it all back apart and weld this nut back down, and decide if I want to replace all the hardware or risk it happening again. Fuck metalcloak man
Ah okay. Well hopefully it isn't in too rough of shape and I can make it work for a bit. I'll have to take it apart and see what kind of shape the drums and bearings are. I may or may not try to salvage them based on that, and how awful it will be to wire them vs. wiring new ones.Those are some very old axles under that trailer but they are good for 3.5k each or a touch more depending on tires. You are going to find parts for them hard to get to borderline non existent. I would give them a good serve now so you know the bearings and seals are in good working order and save up for some 5200# axles and new tires/wheels.
Why go for 5200# axles over 3500#? 2x3500# can carry 7k right?
Been busy with important but unglamorous prep work for Moab.
In the truck, I flushed the coolant and brake fluid, so now all the juices in there are new since I picked it up except front diff, which isn't really necessary since it runs in 2wd most of the time.
First test drive completed, about 50mi, some dirt road, some 45mph, some 60mph. Pulls just fine
I'll be putting the camper on the truck today and taking the full setup out over the weekend!
The duct tape rides again!!!!!!!
Reminder
