Ohio 1946 LJ 6.0 with Dana 60's
Shank
NE Ohio
Price
39000
Salem Ohio
Listing for a very good friend (I absolutely hate to see this sold - was hoping I could purchase this but it doesn’t make sense right now). I can get whatever information needed and will obviously get you in contact with the owner (who built this).
Titled as a 1946 Willys MB.
Engine:
2005 6.0 Chevy 85k miles
Current Performance modified factory harness
Tuned by Wayne Hartwig 150 Tunes
ARP stainless exhaust studs
PSC power steering pump and remote reservoir
Be Cool radiator with Mercedes high volume fan
Brakes:
CNC dual master cylinders and pedal with bias adjustment
Front and Rear shut off valves
CNC dual cutting brake
F350 dual piston disc brakes front and rear
High Angle Driveline Transfercase mounted disc parking brake
Trans and T-case:
Rossler 4l60e with Art Carr Winters shifter
Atlas II 4.3 ratio w/ 1350 flat flange
JE Reel 1350 driveshafts
Axles:
Dana 60 Superduty front with gusseted kingpin conversion
35 spline inner and outer axles with CTM joints
ARB and 5.38 Dana brand gears
Broached Spicer lockouts
Dana 60 rear full float
Alloy 35 spline shafts with SOLID drive flanges
Suspension:
Old Man Emu springs and remote reservoir shocks
Triangulated, adjustable 4 link rear
3 link front
All heavy wall tube with HD Ballistic joints
High clearance
Other:
WARN 9.0 RC winch with synthetic line
ARB HD Compressor with air chuck port
USB Ports
LineX
Mastercraft seats with covers
11ga steel body
Lockable under seat storage
Optima w/ cut off switch
TIG welded stainless exhaust with stainless Borla muffler
Aluminum skin over rollcage
H2 wheels with OMF weld on bead protectors (5)
39.5 13.5 17 IROK tires (5)
Flaming River Stainless steering column w/ billet mount
Willys gauge cluster w/ Autometer gauges (speedo needle broke)
Rust free LJ frame, shortened, bobbed, narrowed front
Full HD skid plate
Clean, zero rust
$39K no trades, I have too much stuff
More, high resolution photos available for serious buyers
Very nice Jeep. It says it's on an LJ frame. What's the wheelbase as it sits?
Reactions: Shank
You’d be hard pressed to build this for double as I said, someone needs this one.
