Thanks again!You also need to know the free height of the OME 2941 and 2942 for a real comparison. Ideally, what you want is the lightest spring rate and the longest spring that will give you your desired lift height (~2")
All of our TJ's differ in weight to some extent, so there is no set ride height these springs will give you, only estimates.
OME 942
Free Height 14.96"
160 in/lbs
EXP 55298
Free Height 13.54"
175 in/lbs
I can't find the OME 941 Free Height or Spring Rate
Looks like the OME 2941 clock in at 15-1/3" Free Length and 140 lbs/in2, which would further solidify your recommendation.
