Brake line
grabeb
Kansas
while under our 01 Jeep I noticed the brake line going to the rear brakes looks kind of gross. Almost a rusty appearance. I have zero clue what those were made of, but guessing it is steel and thus likely is rust. I'll try to get a pic uploaded, I posted one elsewhere asking about the undercarriage.
So, if I go to replace it can someone recommend a good place/brand to buy? It appears Amazon has a Dorman 919-221 Stainless kit that says it fits. But so does Dorman 919-200. I'll go to their site and see what I come up with because I'm not seeing a difference, but there has to be.
I have had good luck with Classic Tube & Inline Tube for these sorts of things, although I have not used them for any of my TJ projects.
Reactions: Sean B and grabeb
Went to both that site and Dorman and both had multiple listings. Turns out the difference is Dana 35 and Dana 44 axle. Guess I need to figure that out on the 01 Sport.
Edit....went out and looked and the front is a Dana 30 and the rear is a Dana 35. Answers that question.
I see everyone listing stainless brake lines. Probably good deal in long run IF fit is good. I bought some stainless lines, coiled for the drop from master to axle for suspension travel, on my 60 suburban and they were a nightmare to work with.
The shape of your rear diff will positively identify which you have. Although I wonder what the differences are? I wonder if the brake wheel cylinders have a different thread pitch? I supposed the bends could be slightly different but I honestly would've guessed that the axle type didn't make for a difference.
My guess is minor differences to the shape when following the axle. My experience on stainless lines are they are a PIA to work with IF not a perfect fit. That was my issue on my 60. They don't make lines for that, at least not once you piece mill the entire brake system to get a booster and double pot master so you have parts from new trucks.
Reactions: hear
I replaced mine with an OMIX set, but I can't find it now. Don't forget to check your fuel vapor lines as well. They are very close to the exhaust.
EDITED TO ADD: I used the Classic Tube stainless kit for my brakes. The driver's side front and rear were formed exactly backwards, and I had to wrangle (sorry) them into place with a tubing bender and lots of cursing.
Reactions: grabeb
I'll do that. I suspect an issue with the vapor system as she doesn't like to fill without constant clicking and a check engine code.
Reactions: glowell222
