Alright guys, I’ve tried everything that’s been suggested and still havent found the solution to my cylinder 6 misfire problem. 2002 TJ 4.0. I hear it at idle and feel it when driving as well. Did a compression test, everything looked good, did a fuel pressure test, that looked good, just checked the injector wires with a Noid light, swapped #5 and #6 injectors to see if the problem followed and it didn’t, and put brand new spark plugs in(twice) and changed the coil rail. Also swapped all the o2 sensors. Any ideas?
