Part numbers and resources for constant tension hose clamps
I know this is an old post, does anyone know if the "47" listed for the clamp for lower radiator hose (at the radiator, not the water-pump) is referencing the "MM"? I'm about to order from Clips and Fasteners and want to be sure I'm getting the right size.
thanks in advance!
I believe the number of the clamp is the nominal diameter in millimeters.
Reactions: Viking Jeeper
I've compiled a list of part numbers for the constant tension hose clamps for our TJ / LJ cooling system over the last couple of years. Due to various reasons, my Jeep now has worm gear clamps on it and at this time of year when the temps get cooler, I start getting leaks at the ends of some hoses, requiring a little tightening of the clamps. I'm going to be overhauling my cooling system sometime soon, so I thought I'd post up these part numbers and some links. Thanks to @Jerry Bransford for providing a link to Clips and Fasteners on a similar thread on another website.
When I bought my '06 in 2016, this is what it had on the hoses (the number stamped into one of the end tabs). I plan to put these same sizes back on. I don't know if these are exactly the ones put on at the factory, but it's what was on mine.
42 on upper radiator inlet
47 on thermostat housing
55 on water pump
47 on lower radiator outlet
24 (both ends) on the smaller heater hose
27 (both ends) on the bigger heater hose
I ordered these from MOPAR Parts Overstock:
04401438 - stamped 44
04592176 is stamped 47
55037990AA - stamped 50
55037660AA - stamped 55
Jerry provided a link for the clamp stamped 42. They come in a box of 5.
42 clamp at Clips and Fasteners
This site has the 24 and 27 clamps for the heater hoses as well as the 42 and 50 sizes, but they are in boxes of 10.
Zoro 24 hose clamp
Zoro 27 hose clamp
Another option for the heater core hose clamps are to order these hoses from Amazon. Both of mine came with the hose clamps already on the hoses.
Mopar 5503 8128AC, HVAC Heater Hose
Mopar 5503 8223AD, HVAC Heater Hose
There was a MOPAR part number of 52005580 for the 42 clamp. I ordered one and it appears it has be replaced with 55037990AA and had 50 stamped on the tab. There were two per package.
Will this work on the ‘99 4.0? On mopar it tries to say that part number for the water pump doesn’t fit and directs me to a different one. Also it shows no part number on mopar for the lower radiator outlet either. Just want to see if anyone has used these on a ‘99 so I can buy once and be good to go.
For some reason the Mopar parts books only show one part number for all 4 of the larger clamps. Mopar Parts Giant also said it wouldn't fit on my 2000 4.0 water pump but it did. Anyway I ordered all the part numbers per the original post and everything fit fine on my 2000. Since your 99 takes the same water pump I don't see why it won't fit.
P
Perfect! On that note is the thermostat and radiator the same as on your 2000?
If so I’m going to do all 4 while I’m in there.
I need to get the emergency worm drive clamp off my lower radiator hose and put back the proper clamp, But as my luck would have it my broken clamp is not marked like others earlier in this thread. I don't want to drop the hose and have the wrong clamp hence my asking for expert help.
Got the clamps in, the #42 clamp that's supposed to go on the upper radiator inlet won't work with a #50 clamp that Mopar has replaced it with. I tried it on my jeep (1997 2.5L wrangler) and it just slides over the hose. You're going to have to find a smaller one as mentioned before. I did find another source for the #42, but you have to buy five of them:
https://www.amazon.com/DBG-Ventures-CONSTANT-TENSION-37-2MM-44-5MM/dp/B08BWYWFY2/?tag=wranglerorg-20
The great news is that all the other clamps in the first pose work great with the exception of the #50.
You guys should read my posts earlier in this thread … it’s pretty clear and pretty cheap.
Reactions: MountaineerTom
Just wanted to add to this thread. I appreciated the Mopar part numbers in the first post, however, since there’s some weirdness with the 42 arriving as a 44 and the 47s arriving as 50s, I decided to go with Bel-Metric.
I don’t have part numbers because Bel-Metric didn’t send me any emails for my order and the website is currently down. However, the following worked perfectly:
42MM x 15MM - upper radiator
47MM x 15MM - thermostat housing
47MM x 15MM - lower radiator
55MM x 15MM - water pump inlet
27MM x 15MM - (2) heater hose
24MM X 15MM - (2) heater hose
All of them are super snug, like you’d expect stock to be. I also like how they’re all black. Overall for $26.61, I think that’s very fair.
I just read the original post and what's on this page. I've been wondering if anyone has eitheir gotten the correct new clamps or tried to reuse the original clamps and had problems with them not fitting because the replacement hose had either a thinner or thicker "wall".
Just asking because I had this issue with at least one, if not a couple MK1 VWs and everything is still original on my TJ-R except for a new Mopar water pump and I know that nothing lasts forever.
I still had some factory original clamps, and some that were replacement factory clamps from years back that I used to replace the worm gear clamps that I used when I was a jeep newbie 11 years ago. I’ve never had any trouble using any properly sized clamps on either old factory or new aftermarket replacement hoses. The hoses I’ve used (Gates and Continental) have always seemed to be about right in thickness so the clamps work.
Must be a pretty big range in those clamps, my thermostat and lower radiator have a 50mm clamp on them. When I did mine, I cleaned up the factory ones until I could read the numbers and ordered them that way.
Yeah, not sure. I got rid of most of mine early on, in 2013, and then in 2016 when I needed to do an overhaul I added them back once I learned that constant tension are better. But I struggled to find the exact right ones back then, so some I got from Amazon, some from Mopar, etc.
After researching what others removed, it seemed that most had the same MM measurements that I listed, which is why those are what I ordered from Bel-Metric. I'm glad it worked out. From the Bel-Metric website, I want to say the clamps in the 42mm range had like 5 mm diameter difference from max open to at rest.
I will say, I'm surprised a 50 could work where a 47 worked for me. That seems like a drastic difference. As far as I know the thermostat housing and radiator lower hose hookup never changed, so I would think they would all *need* a 47, but who knows.
Reactions: Mike_H
