First post here. I have a 2004 Tj Sahara with 4.0, 5 Speed manual and about 95k miles.
It's basically stock.
Current status:
Jeep wont start. When I turn the key, it clicks once then everything turns off. The cable is tight on the battery, but if I move the ground cable slightly battery, it resets it and I can try again. Unsure if coolant system is working right since wont start, but the last short drive seemed ok.
Recently I had 2 issues that popped up with starting and cooling. I suspect they are unrelated, but not certain so I will give some details on both issues.
Coolant:
I first noticed a lot of coolant leaking after a short drive. On closer look, the bottom radiator hose was disconnected from the radiator. After it cooled, I reattached and filled with coolant again.
I replaced nearly all of the coolant system about 5 years ago. That might have been 30k miles ago. Since then I have not really needed to add more than a small amount of coolant when I check it.
After getting the jeep to start temporarily, I found that it was quickly overheating. I turned the heat on, and that quickly dissipated the heat. I tried to burp the cooling system again. For a short drive, that seemed to help, but then started having problems with starting.
Not Starting:
Before I really had a chance to confirm if that was a good enough fix for the coolant, I started having issues getting the jeep to start. It would click and everything would shut off.
After trying to jump and charge the 4 year old battery, I bought a new battery. That still didn't fix it.
I did some tests swapping fuses & relays, bypassing clutch safety, checked voltage going to starter, and disassembled the ignition switch in the steering column. Nothing appeared to be wrong physically with the ignition switch, so I put it back together and back on. I tried again and then it started. I got it to start and drive a few times before it became a problem again.
What are you recommendations?
Thanks!
Current status:
Background:
Recently I had 2 issues that popped up with starting and cooling. I suspect they are unrelated, but not certain so I will give some details on both issues. Coolant:
Not Starting:
Thanks!
