Made some mounting posts for my front sway bar quick-disconnects. Drilled and tapped a hole in the frame then drilled a hole in two bolts I had laying around. Cut the bolt heads off then threaded them in and added a few tack welds for added strength. Sprayed the inside and outside with frame coating.
Did you just use regular steel bolts for this? Galvanized? Stainless?
1/2"?
