Texas Dana Spicer 4.10 Dana 30 High Pinion (Reverse) Ring and Pinion set
machoheadgames
LED turn signal club
Dallas, TX
Price
140
Will not work on a stock TJ front axle - must be high pinion 30 swapped
Dana Spicer brand high pinion Dana 30 gear set for sale.
706930-4X set
$140 shipped. $125 local pickup in DFW.
4.10 Ratio
These are OEM, NOT the cheaper Dana SVL line. Good quality gears.
These are still new, there is some gear paint residue because I began installing them but did not finish. Reason why is because my rear 4.10 set arrived mismatched. I could not get a replacement 4.10 set, so I decided to order new front and rear in 4.56 instead from Revolution. There is absolutely nothing wrong with this gear set.
Will arrive in a Revolution Gear box as that’s the best way for me to send these parts securely and I have some spare boxes so it’s easiest.
