Spent some time today modifying my new to me pillow block for a grease zerk and getting the lower shaft/pillow block installed.
After taking it apart i noticed the race and bearing cage are both split. For you guys with less than ideal clearance that is a good thing. You can sand/grind the gap larger so the bearing can become smaller and take up the slop on the shaft.i did a little but mine was in great shape to begin with.
I noticed the rubber bushing had slop in the clamshell holders.
So i tightened them up too by using a chainsaw file to oval the top bolt hole and bent them closer together
That took care of the shaft wobble there.
Then i moved on to making the assembly greasable!
Drilled a hole in the front clamshell through the bushing to where the bearing race sits. Further out might not give the bearing as much grease and just send it around the plastic seal housing.had to bend the lip flat next to the hole to make room for the fitting
Found a 45* grease fitting to get the zerk out and away enough for the grease gun
Works great! Stop putting in grease when the seal housings on the end bulge slightly from pressure so they don't pop out
Its rock solid now. There's as much deflection in the steel mount to the frame as in the pillow block now
I decided to clock it down so water wouldn't run into the rubber pillow block hole
