Can I get the wheel hub off with the spacers still on? I can still get to the axle nut.
Do you have 2 spacers stacked? Or is that a casting line?
Yes, you should be able to remove the whole hub, just 3 bolts on the back side.
I've never seen spacers mounted like that.
Guessing they removed the original hub studs?
Wait, what axle is that?
I might be tempted to force a big easy out in the hole but easy outs are hardened to the point of brittleness and could snap if you put sideways pressure on it.
Weld a nut to them and back them out. Or buy a set of hubs.
I have one hub already and a flex core welder so I have options I suppose.
I would hope with that sketchy AF setup there is some red Locktite involved. You will need to put some heat to the head of the screw to get it to release.
If you are going to weld something to it, grind the head of the screw and what you are welding to it clean. And burn it in hot so you get some penetration or its just going to come off.
Or, cut off all you can of the outer spacer to expose the heads of the screws. And grab the heads with big visegrips or channel locks.
I would just buy new hubs and rotors and throw that whole mess in the trash complete.
Since I try and always update with my fix, I did get a few stripped bolts out. Eventually I got sick of the extractors popping off and drilling the head out so I just replaced the hubs. Easy enough. Will tackle the rears tomorrow.
You've put in a lot of work on this rig. I hope it's coming together (at least from a safety standpoint).
