Hi. I am new to this forum. I have a 2000 Wrangler TJ 4.0L in the UK. Engine turns over but does not start. Fuel rail is full and shows pressure when release valve is pressed.
I suspected problem was with ECU so had the unit reprogrammed in the States with the SKIM deleted in case it was an immobiliser issue (neither key would work). I disconnected the key surround unit. Reprogramming did not make any difference.
I think there is no spark. Any ideas, and how do I test if it is ECU or perhaps crank shaft sensor?
Also does any know of any Wrangler specialists in UK.
Thanks
Thanks
