Sorta dame here… I bought it when doing a full restoration of a 1970 Nova and it was 100% necessary but can't remember exactly why.
Milwaukee m12 3/8 ratchet. Bought it to reinstall my radiator after I removed it using hand tools. I’ve got a full hand set 1/4, 3/8, 1/2 + impact but that ratchet changed my life. Install radiator, moryde tailgate, build kids baseball hoop. Its my goto.
That is the most dangerous tool I own.Not even remotely the most used, but its my favorite when I need it Have had it for 30+ years and maybe used it three times.
Had to drill two holes in a very limited space today. Had enough room on top to transfer punch, but not drill with a normal drill. The back side I could drill no problem, but was in a pocket and I couldn't accurately locate the hole locations.
The Sioux was a hair too big without a bit. The Makita with a short flute 1/8" bit was 3.25 from the back of the head to the tip of the bit
So I drilled an 1/8" pilot hole in the transfer punched location on top, and then opened it up to size with a regular drill and drill bit from the back side.
But knowing what's coming you can position yourself accordingly. Maybe
The chuck key will spin around and pinches the end of your finger off when it gets it between the key and the housing. The lever is way too easy to push when changing a bit. Only tool I own that I have to unplug to change bits in.
Have not gotten got like that. Yet. But yea it has a hair trigger.
Stick the chuck key it it and gently turn it to see what it does, unplugged.
I struggle to not do that already Not gonna do it just to see.
The fluke amp clamp multimeter is great for so many things. Well worth the moneyMy most used tool set is my packout 1/4” and 3/8” set.
Electrically
I like using my fluke multimeter
Power tool wise
I can’t pick one, anything Milwaukee works well.
Most used tool is my welder, but my favorite tool(s) are hammers. I've got about 15 different types of hammers. Some I've made like this little ball peen that I use all the time.
Then this 10lb sledge I welded to a jackhammer spike for when you need to hit something really hard & you only want to hit it once.
I think my hands would only want me to hit it once.
Damn - with those forearms, that big hammer looks right at home.
