Work Bench & Garage Version 2
Very nice. Might want a slight upward angle in case you bump into the shelves the grinder won't fall off. Also that will transfer the weight a little more towards the bracket.
Edit: like 10°-15° should be enough
Reactions: FarFire70
Agreed. That'd be the plan. Pics were a quick 30-sec 'would this work'. I'm thinking I'd put short bars below the grinder holders for the discs (bar would be at an angle too ;)). Just make a taller base plate.
I use a piece of flat stock and hang them by the wheel guard (no pic at the moment). Same sorta idea as the round bar, but doesn't require the handle (which is generally not mounted on my grinders).
Planning to repurpose this area with auto tools that are on the shelves now since this is a wasted 'catch all' right now that I throw in the extension cords but rarely grab till from...
Rehomed the auto related tools. Makes sense to me to have them here.
Creates new shelf space
Have to figure out where/how I plan to store extension cords. This will join my other pile to figure out. I'll figure out a new home for the drills too...
This stuff goes to the basement.
This workbench project has made me focus that the garage is about garage tools and the shed and basement can store the other tools...
Worked on the grinder storage solution.
I'm using 14ga since I have a 24"x48" section from when I bought some for repairs on my torque boxes. I think 1/8" would be sturdier but, once I mount it against the full plywood sheet on the side of the shelving unit, I think it'll be plenty sturdy.
Used angle iron as a straight edge. I tried to use it by pushing the griding disc across it but drifted on my first cut. Started using the iron as a guide for continuous plunge cuts and had much more success.
I'll be mounting it with 1/4" bolts I have lying around.
Used my HF Belt & Disc Sander for the first time. I really like how easy it was to get consistent angle grinds and add chamfers.
Definitely not my prettiest welds, but I think they'll hold up over time. I didn't do much to clean up any of the splatter since it's just a holding tools in the garage.
Primed it with self-etching primer front and back and hit the front with flat black. I'll get the back tomorrow.
Also put together a mounting plate for my vise on the workbench.
Took about 3 hours. I could have been quicker but I took a bit to get to learn the sander and figuring out a best approach for the straight cuts.
I'd use this experience to convince the wife that I need a plasma cutter. But I barely got 'approval' to spend these few hours in the garage on Mother's Day weekend.
So I won't push my luck, so I stay on this Earth...
Reactions: NashvilleTJ
Big, enclosed cabinets can hide a lot of tool purchases.
Just sayin’…
Grinder holder install.
Vise mounted (finally) with the metal backing plate:
I love the grinder setup. Out of the way but easily accessible.
Vise is needed for a couple upcoming project so glad it's secured in place. Ran a double (side-by-side) 4x4 within the workbench in that area to mount the vise. 6" bolts to hold it in place.
Eyelet lag bolts into the ceiling joints installed and made use of... There's 6 eyelets up there.
Changed over the welder to 240V for today's project (in my build thread), probably overkill for the metal thickness.
Realized the tool cart needed to move over a touch. :rolleyes:
Floor jack fits in between the cart and paint cabinet, barely, by nudging over the cart.
Funny the little details you miss sometimes in moving things around.
