Hello US TJ World !
I am strugling since many months to fix an engine starting issue with error Code P0340 (no signal from Camshaft sensor)
No ignition.
I have done the following:
- Buy a ODB II reader : Done => error P0340 appears each time I start to run the engine
- Cranckshaft position Sensor Replaced with the same 560 XXX part : Done !
- Camshaft position Sensor Replaced with the same 560 XXX part : Done !
- Read TJ Reparation Manual and how to diagnose P0340 issues : done !
- Check +5V on sensors : done !
- Check good ground negative : done ! (less than 1 Ohm)
- Check Wiring between PCM and both sensors (Crankshaft and Camshaft position) : done !
- Check Temperature sensor on Magnifold and coolant liquid : done ! (no short circuit and 10 KOhms for both)
- Check Distributor Finger : done!
BUT..
I have realised yesterday that the distributor finger is always in the same position even after many tries to start the engine (the starter motor run well)
Finger
So I would appreciate some help to answer some questions:
- Is there any kind of clutch release mechanism which should explain this? Maybe the finger stays static even when the starter run?
- On which bolt part can I try to engage manualy to make the motor go ahead slowly to check if the finger moves?
My wondering : there is probably a defective part inside the Distributor which would have cause the disconnection from the camshaft gears. Can this appear?
Thanks a lot for your advice
Jerome
My post on the FR - Forum :
https://www.jeepmania.com/Forum/viewtopic.php?f=40&t=87435&start=30
No ignition.
BUT..
Finger
Jerome
