Thanks
Based on my VIN I guess that’s it’s a 97 quirky one :s
Letter V at the 10th caracter
Well it's easy to test the pinout, just unplug the sensor and see if you measure 5V (key on, engine off) against the middle pin as ground. Whichever pin has 5V on it will tell you which diagram to use.
I have not the TJ97 electrical diagram (below the 2004), but I guess that it's approximately the same.
1. I have checked too the coil (resistance seems to be good but I will replace by security). My part has the number 56027966 and I am advised to order the following one :https://shop.asp-eberle.com/en/coil-ignition-2.5-l.-4.0-l.-id-0417.20 with number 5234610 (crown). Do you know if this should fit on my 97 TJ 4.0 ? I guess yes, but I am wondering why this is not the same number.
2. I have tested the voltage on the Crankshaft connector (with both crankshaft and camshaft sensors disconnected), when contact is ON : I can see the 5V on the pin 1
And I have too 5V on the pin 3 => I am wondering why?? It should be 0V no ? (the crankshaft sensor is disconnected when I check the voltage on the plug)
you will see 5V on the sensor until something passes through the sensor, which then pulls the signal down to ground.
With the sensor unplugged, as he noted? He said that, with the sensor unplugged, he's seeing 5V on both the supply and signal pins on the harness connector. Unless I misread...
Did you recently replace the rotor and distributor cap? Have you checked to see if the rotor and distributor cap are in good condition? No scaling on the terminals inside the distributor cap? No hairline crack in the cap? No moisture in the cap? Do you have the correct rotor? I know at one time auto parts stores called from the wrong rotor in their look-up database for 94/95 YJs with 4.0 engines. I seem to recall early 97 TJs were built with the same rotors as 94/95 YJs until the inventory of YJ distributors was exhausted.
Do you know that the TJ Resources form has parts lists and factory service manuals that you can download? Check it out:
https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/
It looks like the OEM coil is still available from Jeep, but it's very pricey. I don't know if aftermarket coils are acceptable substitutes or not, though. These days, a lot of the aftermarket stuff is junk. Hopefully someone else with a 97 TJ can add some comments to this thread.
That does appear to be the correct pinout for a 97, according to the manual in the TJ Resources section. I wouldn't expect you to see 5V on the signal with the sensor unplugged. Oddly, the P0340 code is for no camshaft sensor pulse detected, not crankshaft sensor. It seems that you have a short between the 5V sensor supply from the PCM and pin 3 somewhere in your harness, or your PCM has an internal short. With the crankshaft position sensor unplugged, do you have continuity between pins 1 and 3 on its connector? That would indicate a short somewhere...
I suspect bad harness.
2. I have found 5V between ground PIN and Power Supply PIN
3. When the car key is removed : I can see about 1k Ohms between Supply PIN and Signal PIN (when PCM connector is plugged): Why???. If I remove the PCM connector (black one), infinite resistance.
I don't think so. I think it's the PCM. Here's why:
#2 indicates a short between crank signal and sensor power. The last sentence in #3 that I bolded indicates that the short is in the PCM. If it was in the harness, unplugging the PCM would make no difference.
Paging @Wranglerfix - Mark, have you seen shorts between crank position sensor signal and sensor 5V power inside the early PCMs? Is that a typical issue?
I think I disagree. You would expect 5V across the power pin (the 5V reference) & ground pin.
1. I have found 5V between ground PIN and Signal PIN
