Hey, Maverick26_Fr, I've learned something new in another thread that may explain the 5V on the signal you're seeing with the crank sensor unplugged. Apparently there are pull-up resistors inside the PCM that keep the signals at 5V nominally. See the posts after the initial one in this thread:
[URL]https://wranglertjforum.com/threads/crankshaft-camshaft-position-sensor-voltage.72437/[/URL]
Knowing that, I no longer believe your PCM is the issue.
Hello Sab
Thank you very much for your message (appreciated) and these information. I was a quite worried by the PCM replacement
So I will try to cut and weld some wires on both sensors signal in order to investigate more.
If someone has an advice about an oscilloscope model which I can buy on amazon.. . I will ask too some friends to see if they have that in a garage..
I have had an Hameg in the past (electronical school matter), but I sold it 10 years ago.. not thinking that it could be useful again!
